Houdini 16 to UE4 Pipeline: Fails to export.
   8417   7   2
I have come to the conclusion that I don't know what I am doing wrong. Basically, I am following this video {https://vimeo.com/200486713 [vimeo.com]} to create a simple fracture sim and then want to export the RBD sim as a vertex texture for UE4. For some reason, the exported FBX is only 8kb and I can't import it into Unreal. Also, the baked textures look wrong too.
Downloaded the GDC2017_VertexAnimationTextures.zip and copied the nodes exactly and it still fails to export properly. If I open up the file provided by Luiz, I can export it fine there.
It would be really helpful if someone could look at my file and tell me what am I doing wrong.
Also, vertext_aniamtion_textures in H16 is a subnetwork and looks different than the videos. I can import the node from provided by Luiz but it still doesnt work.
Cheers.
Ball_Explode_Test_01.hip (4.2 MB)
Hi yurid9,
I've just checked your attached hip file and think that your object visibility should look like the first screenshot.
Inside your exploding ball, make sure to make the last node the visible one (screenshot2)
For export i would use rbd to fbx node (screenshot3).
Should work then.
Best regards,
Johannes
Edited by ZN-Games - March 20, 2017 20:04:33
Didn't know object visibility does anything other than show/hide the object. Gonna go home and take a look at the things you pointed out. Thanks a lot for your help
Cheers.
ZN-Games
Hi yurid9,
Should work then.
Best regards,
Johannes
Alright I figured out what was happening. I was installing the HDA provided by Luiz by going to Assets tab on the top and clicking on Install Asset Library. What I tried doing today was to copy and paste the HDA inside houdini\otls and it works
Cheers.
I don't think that GDC2017_VertexAnimationTextures.zip is needed for completing the tutorial you mentioned (just use RBD to FBX), but if it works for you, it works for you
Edited by ZN-Games - March 22, 2017 13:16:38
I'm glad you guys figured it out We're hoping to have that HDA in the build shortly
Luiz Kruel
Senior Technical Artist
Hello everyone.
I have some troubles with export to ue4
I'm using RBD to FBX node in OUT
It is building (imported fbx mesh) after voronoi scattering and using for them RBD Objects tool
In houdini its looks OK, but after exporting fbx to unreal engine in anim asset pieces just chaotic fly around
What is the problem?
Hey Anton,
perhaps you could try to open your fbx in some other program, just to ckeck, whether the problem is on the unreal or houdini side.
Also updating houdini to the latest nightly build sometimes solves importing/exporting problems, as many of these features are new and get updated frequently.
