hi guys having some trouble in houdini 16 following a tutorial from houdini 13 with the group node with filter expression
below is the image i attached anyone plz help me how to do this in houdini 16.
group node filter expression
5400 4 1-
- deadpool111
- 10 posts
- 9403 posts
- deadpool111
- 10 posts
- timotheos
Cheers guys,
I´m completely new to Houdini and I`m also having trouble with the new organisation of Group nodes.
Like you can see in the pic attached, the tutorial filters by expression in the group node using an older Houdini version.
I think I have to use the groupExpression node, like explaned in the post above, but I don´t know how to “convert” HScript “$CG > 0” to VEX.
Looking forwards to ur answers, thanks in advance!
- neil_math_comp
- 1743 posts
I'm not gonna lie. I had to look up what
In the Group Expression SOP, you can use
$CGmeant.
@Cd.g > 0.5as the expression. It's the Cdattribute, hence @Cd, (and VEX knows that Cdis normally a 3-float attribute, so it can guess that without needing the v@Cd), and the .gis an alternative to .yfor accessing the y component of a vector.
