Carve Node and Attributes
   6745   4   2
I had some issue using the Carve SOP trying to drive it with attributes.
Does anyone know how I could achieve a custom / randomized carve-amount per line?
I couldnt get it to work with point attributes nor with prim attributes… Or do i have to use a completely different Node?
Carve SOP cannot use attributes for per-prim carves.
A foreach loop is required to do individual carve values per curve/surface.
Thanks a lot jsmack
Carve is verbified, so the foreach loop can be compiled to get more speed.
Edited by goldleaf - Aug. 25, 2018 18:02:04
compiled_carve.hipnc (102.6 KB)
I'm o.d.d.
Ah crap, i was trying just that, to use an attribute transfer on a carve SOP but that does not work? No way to reveal curves with an attribute transfer using the carve sop?
A.
