Hi
ow can I fix this one, on a fresh centos install and houdini I get this when I want to open a shell window
sh: xterm: command not found
when I start houdini from a shell it logs stuff there, but if You close it it is quiet and You can not open a new one
thanks
Martin
Centos: xterm: command not found
5088 2 0-
- sanostol
- 612 posts
- Redcroft
- 13 posts
- sanostol
- 612 posts
ah, just saw it, thank you
this gets logged soon as I try to open a shell inside houdini with Houdini>Windows>Shell
when running houdini from a terminal, all logs are in the terminal, but if You close it, they go nowhere.
is there a way to reopen a shell so You can read logs?
thanks
Martin
thanks
Martin
Edited by sanostol - Nov. 8, 2018 11:22:34
