In Mantra, how could I rotate a texture pattern VOP, like Stripes VOP node?
   2126   1   0
Hi;
To assign a stripe pattern texture to a polygon, I used “Stripes VOP node” in mantra material builder, but I don't know how to rotate it.
Any idea?
Is there same pattern generator in COPs?
Thanks for helping.
Edited by Masoud - May 11, 2019 12:33:46
Masoud Saadatmand (MSDVFX)
If you put a UV Transform vop down, you should be able to rotate the pattern. I'm using rest position as uvs, works just fine
Edited by Colby Winfield - May 15, 2019 16:41:47
