Hi, I looked up the example, it does create the hinge constraints when connection type set to “Hinges”, but it doesn't create a constraints name for it or anything, how do I feed it into the rigid body solver? In the 17.5 demo, we see how he drew the hinge constraints for the door, kinda want to know the little trick here.
Thanks in advance
How RBD constraints from Rule (hinges) work?
4675 4 2-
- ouroboros1221
- 79 posts
- npetit
- 447 posts
- ouroboros1221
- 79 posts
npetit
The rbd constraints from* nodes only create the geometry with a name and restlength attributes. You need to pipe that into an rbd constraint properties node to set up the constraint attributes.
Thank you npetit, it's very helpful. It seems the door hinge demo was essentially a hard constraint then?
- npetit
- 447 posts
- Seaton
- 22 posts
