Font Support for European Characters
   5448   4   0
I am curious whether support for non english fonts could be implemented?
It would be great if I could use eastern europen fonts with Font sop or Cop.
It's there already. Just get your font, and tell the FONT SOP about it… There's a button on the Font Sop: “Start Font Manager”. Check it out…
Here's a quick example. I created a new directory called $HOME/houdini/Fonts where I keep all my extra fonts. There's an environment variable: HOUDINI_OUTLINEFONT_PATH which knows where your fonts are. You can add this new dir to that var, but it's not necessary. SideFx suggests you use $HOME/houdini8.1 (etc) but I prefer to use a dir without a number (ie. “houdini”) so that I don't have to keep moving my fonts as the version numbers change.
Let's get a new font, eh? Go here:
http://www.1001freefonts.com/fonts/afonts.htm [1001freefonts.com]
I grabbed the first one in “A”. Unzipped it and put it in the dir above. Load it with the Font SOP's Font Manager (and I saved the new list of fonts into my $HOME/houdini/Fonts too…)
Then select the new font from the menu, and hey presto!
cheers,
ben.
''You're always doing this: reducing it to science. Why can't it be real?'' – Jackie Tyler
I knew about it, and am using it. This is not the problem.
The problem is that I can not use extra characters from the font set. For example when I type - õ á - or something which contains umlauts the font operator returns just spaces.
Use the following syntax
\code
where the code is a number of character in charset.
f = conserve . diffuse . advect . add
fx td @ the mill
Super, that works.
thanks for the help
