This is a ridiculously big topic, but I have one simple (i think) requirement. I need to create a gently rippling water surface for animation. I'm not doing any underwater shots, but i'm going to be putting a river bed under it, and objects under the water's surface.
Can anyone help me out with a starting point, some tips or advice, or perhaps just tell me to go and film it instead?
Tom
Water
26053 21 1-
- djpeanut
- 9 posts
- the_squid
- 132 posts
There are some VEX shaders which do a pretty good job of creating the look of a water surface if you want to go the shader route (VEX Choppy Water may be a good place to start) Keep in mind VEX Choppy Water is only a displacement shader. You'll need to assign a shader for color and refractions and reflections and such to finish the effect. VEX SuperMaterial is a good place to start if you want to get the ocean surface to shade properly.
Alternately, Houdini gives you the option to directly manipulate surfaces in SOPS. At the sop level, create a grid on the ZY plane. Set rows and columns to be 40 and 40 and add a “Vex mountain” sop. In the VEX Mountain sop set fractal depth to 3, Roughness to .6, Height to .025, Frequency to 6, 6, 4, and offset set to $F/900, $F/500, and 0.
This will give you a fractal noise that moves over time. It may not be a duplicate of the surface of a lake, but its a good place to start.
If you like writing your own functions, bypass the Vex Mountain route and use a Point sop instead. In the $TX field in the point sop type:
$TY+noise($TX*9+$F/150,$TY*12+$F/70,$TZ*9)*.03
That'll create a moving noise pattern on the surface as well.
To find out more about noise functions go to Windows>Textport and in your textport type “exhelp noise.” This will return a list of the available noise functions…
- stevenong
- 1634 posts
Hi Tom,
I wrote a VEX Water SOP which is available on Odforce. Please go to this thread [odforce.net] for an example hip file.
Cheers!
steven
Cheers!
steven
- mstram
- 77 posts
stevenong
Hi Tom,
Cheers!
steven
This is very cool.
I've loaded the file and rendered it, and I'm wondering what's making the teapot “bob” up and down ? I dont' see any keyframes and don't see any kind of connection between the teapot and the water object. Was the animation “baked” into the teapot somewhow ?
How can I get another object to interact with the deformation of the water?
Is there way to use an animation constraint / expression to make an object's center follow the deformation of the water object ?
Mike
- stevenong
- 1634 posts
- mmtpour
- 53 posts
- jesta
- 311 posts
- mstram
- 77 posts
- mmtpour
- 53 posts
- jesta
- 311 posts
- wolfwood
- 4363 posts
mmtpourjesta
you need to uncompress it.
you can use gzip or winrar(if your on windoze).
I have winrar (Im on windows) but i cant even unzip it.
Not known application
I recommend 7-Zip (http://www.7-zip.org/) [7-zip.org] Its the swiss army chainsaw of file compression.
- mmtpour
- 53 posts
- jesta
- 311 posts
- mmtpour
- 53 posts
- MiguelPerez
- 41 posts
- stevenong
- 1634 posts
Hi Mohammad,
Here's the thread with the teapot hip file:
http://forums.odforce.net/index.php?showtopic=2877 [forums.odforce.net]
Cheers!
steven
Cheers!
steven
- mstram
- 77 posts
mmtpour, I get the same load error, it seems to be a missing render entry, but despite the “failed load” message, the file still works (8.1.704).
StevenOng:
Your (VEX Water) SOP is great, btw it seems there is an older version, “water” in the same otl file.
With your water SOP, and now I see an example of the align SOP, and also just found out about the “sticky” object type, I have some basic tools to use for a water scene.
I'm now trying to create some realistic boat wake / spray.
I started to experiment with the particle system, making my “boat” the source. I have more of a “jet engine / rocket exhaust” effect than a boat wake though
I imagine more than one source is probably going to be necessary, along with a bunch of other SOP's to make something that looks good.
If anyone can offer any tips/suggestions / links … example files, that would be great. I'm at a begginer level with (houdini) particles .. (well particles in any program for that matter.)
Mike
StevenOng:
Mike
Edited by - Oct. 14, 2006 15:27:40
- symek
- 1390 posts
- mstram
- 77 posts
- mmtpour
- 53 posts
stevenong
Hi Mohammad,
Cheers!
steven
Yes i can see the teapot now, I still get an error but the file works fine
Thank You.
Mohammad.
