Rigid Body Particles using UI ?
6107 16 1-
- espr3ss0
- 20 posts
I'm completely new to Houdini and I've been looking through some tutorials trying to make some RBD Particles in order to fill a container. I noticed that a lot of people skip using the UI provided and so far seems simpler but I understand things can get complicated.
So I added a Circle and clicked “Source Particle Emitter” then added a Cube and clicked on “Instance Geometry on Particles” which works fine but now stuck trying to make the instance geometry to RBD ?
- 9488 posts
- espr3ss0
- 20 posts
- blackpixel
- 182 posts
- espr3ss0
- 20 posts
- blackpixel
- 182 posts
- vusta
- 555 posts
- vusta
- 555 posts
- espr3ss0
- 20 posts
- vusta
- 555 posts
- espr3ss0
- 20 posts
There is an error on load … Warning: “/obj/geo1/axis_align1” using incomplete asset definition (full definition not found). The following node types are using incomplete asset definition: labs:
op/axis_align
When I go into geo1 there is a ground plane visible but can't select it or see any object in the graph.
op/axis_alignWhen I go into geo1 there is a ground plane visible but can't select it or see any object in the graph.
- espr3ss0
- 20 posts
blackpixel
But in general I'm afraid there is no Shelf Button Solution for what you want to do. The RBD Bullet Solver SOP might be the fastest way to get there without diving into DOPs. Either way you'd have to get your hands dirty one way or another
Thanks I found the file.
I put together a simplified version of the example file, had emitting boxes with a box underneath for them to collide with which seems to work fine but found a similar problem to vusta's file where everything falls down. So I tried taking the example file apart and found that if I replace the RBD Bullet Solver then I get the problem. I'm missing something in the solver but can't see any difference ?
- vusta
- 555 posts
espr3ss0have you updated the sidefx labs tools ? to be safe just do it
There is an error on load … Warning: “/obj/geo1/axis_align1” using incomplete asset definition (full definition not found). The following node types are using incomplete asset definition: labs:op/axis_align
if that's not working…then stuff would be initially below the ground hence fall…even tho the ground is there.
The labs align SOP simply takes an object, aligns its bottom to be on top of the ground (can do other axis too but 99.99% of the time I align it to be on top of ground)
https://www.sidefx.com/tutorials/sidefx-labs-installation/ [www.sidefx.com]
- espr3ss0
- 20 posts
vusta
Thank you soo much ! Just updated and works ok now. I see the Ground Plane is an option in the Solver. One more question on this subject … is there any way to make the object I want to fill static ? Moves around too much.
Edited by espr3ss0 - Feb. 26, 2020 09:42:19
- vusta
- 555 posts
espr3ss0piece of cake, so assuming you're using the 1st file I sent, look in tab2 of rbdconfigure, you'll see @name=piece1 is being pinned, ie it's perfectly still, static. All you have to do is use the dropdown list in group and add piece0 to the list (piece0 is bowl, piece1 is funnel)vusta
Edited by vusta - Feb. 26, 2020 15:56:52
- espr3ss0
- 20 posts
- espr3ss0
- 20 posts
vusta
I have a sligt problem … I have to add a second attribute where 1 is active and the object I want pinned is 2, if I don't do this the emitted objects also get pinned.
Is this just something I'm doing wrong or a bug ? (Apprentice 18.0.348)
