Crowd Agent shapes: Style Sheet is not picking anything up
   4617   10   1
Hi any Crowd people out there.
I have made some crowd agents but when I try to render them, the Style Sheets are not finding any Agent Shapes.
If I ‘unpack’ my agent using the AgentUnpack node, then I can see various shapes, but all with the same agentshapename. Why is that? How can I find out the names of any Agent Shapes, if any exist?
Also, I thought that Style Sheets could pick out primitive groups using an attribute expression, like so:
@shop_materialpath = Skin
However this is not working either.
What is the syntax for this, please?
EDIT: Hmm, maybe this post should be titled “Crowd Agents Shapes - How Are They Made?”
Edited by dansidi - June 3, 2020 11:12:46
Annotation 2020-06-03 153409.png (43.8 KB)
Annotation 2020-06-03 153511.png (17.3 KB)
Annotation 2020-06-03 153605.png (83.2 KB)
It looks like your agent has a single shape (“default.male_01”) that contains several polygon or polygon soup primitives?
I suspect you're also missing an additional level in the style hierarchy. Agent shapes are basically packed primitives, so there is a hierarchy of agent primitive -> agent shape -> primitive (e.g. polygons)
cwhite
Thanks for that.
So…..
How can I create different Agent Shapes when I make an agent?
I have tried splitting the source geometry into different pieces but then what do I do?
Attach each seperate piece as an Agent Layer? That can't be right, surely?
How is it done?
Let's say I have a mesh from an FBX.
The mesh is a single piece, however the primitives have an attribute called @shop_materialpath
I want all the primitives with @shop_materialpath = “shirt” to be one Agent Shape
and all primitives with @shop_materialpath = “skin” to be another Agent Shape, and so on.
Edited by dansidi - June 3, 2020 11:57:38
If you're importing through the Agent SOP, a shape is created from each geometry object. In the Agent Layer SOP, it depends which mode you're using - the Add Shape option in the multiparm creates a single shape from the SOP path, and the Add Shapes by Name option creates multiple shapes from the source SOP based on a name attribute.
Note that you don't really need to create separate shapes for the purposes of material assignment, and there is additional viewport overhead if you increase the number of shapes. Splitting into separate shapes mainly makes sense if you want to combine different shapes together via layers and assign those to different agents.
cwhite
Thanks again.
This is good news, if true.
So, why is my Style Sheet not able to choose between the Shirt, Jeans, Skin, etc?
Is there a way to dig down into the packed agent to find those primitives which have @shop_materialpath = “Jeans” for example?
I have tried many combinations but nothing is working for me.
Please can you show me the syntax for doing that?
Thanks a lot!
Well, by random stabs in the dark, I have found that this works, but I can't tell you why it works.
Such is often the way with Houdini…
Thanks for your help!
Edited by dansidi - June 3, 2020 12:23:27
Annotation 2020-06-03 171628.png (197.3 KB)
That looks correct - the primitives you're trying to target are in the third level of the hierarchy (agent prim, shape, then polygons)
Thanks for that.
My confusion come from (among other things) having used this Style Sheet thingy before when the Agent has Agent Shapes.
Now my Agent does not have Agent Shapes, so I have to dig down into the one shape I do have and pick out the Primitive Group.
Does that sound right?
That sounds right, but it really depends on your source asset and whether its geometry was split up into multiple geometry nodes or not
Got you.
Thanks so much for your help today.
Hey guys,
Is there a way to do this using vex/python as opposed to applying materials through data tree?
For regular assets, we set shop_materialpath to shader path through a custom Python HDA. If I have to do the same for Crowd Agents how can I access this 3 levels deep packed geometry in python so I can map my shaders to geo shapes?
I would like to leverage the existing system to apply lookdev published for the crowd agent assets if possible. Also we are not rendering with Mantra so will need to write crowds to Alembics, thus hoping I can apply my shaders through shop_materialpath.
Edited by Amit Khanna - Jan. 19, 2021 19:16:08
