Import string primvars into SOPs
   3604   2   0
Hopefully I'm missing something simple.
I'd like to create a bunch of points in a SOP network, tag them with string attributes and then import them into LOPs as transforms. I'd then like to use that string data later in a SOP Modify node to drive updated transforms. In my test I'm able to create the attributes that then come into USD as primvars, but when the USD is brought into a SOP network, the string attributes exist but are empty. Any float attributes seem to import correctly though.
Any idea why the string attrs don't work? See attached HIP.
Jon
missing_string_attr.hipnc (108.3 KB)
I still haven't figured out why the LOP import doesn't work, but can access the primvar value with a VEX workaround afterwards in a primitivewrangle:
string stage = "op:/stage/sopcreate1";
string test[] = usd_primvar(stage, s@path, "test");
string string_val = test[0];
Edited by jparker - Nov. 1, 2020 15:58:01
This was filed as a bug today (#109108) so I will assume that's what is going on!
