Volume rasterize attributes on points gives jagged result
   3579   2   1
Hi ! trying to set up a source for smoke sim. i use volume rasterize attributes and get strange results.
please see what's happening
i have a bunch of points distributed across the space. its bound box is rather big (arounb 80x80x80 units)
then i use volume rasterize attributes and get this :
as you can see it is very jaggy. of course i've played with pscale or voxelsize/sampling…but i have not managed to get smooth volume
then i deleted lot of points and left only one group of them:
the same SOP (volume rasterize points) with the same settings gave me different result (nice and smooth volume)
and the question is - why i got different results keeping the same settings both for points and “volume rasterize attributes” SOP ?
the same pscale and the same voxelsize
the only thing that changes is bounding box of my points…
and of course it affects the simulation… i also get ugly jagged volume inside DOP….
i can not understand what is wrong….i thought it is just viewport optimization or something like that….but the simulation also goes wrong and i see this voxels in rendered picture as well…..
how can i get smooth volume for all of my points ?
thanks in advance
Edited by 90okm - Nov. 11, 2020 09:24:02
Do you have Limit Texture resolution enabled? If yes, try to disable that.
If you go to Viewport Display Options/Texture Tab and under 3D Textures folder, you should have a Limit Resolution checkbox.
as i have just checked my render is ok….the problem i have described above is just viewport issue (as you guessed)
and of course this does not affect simulation (that was my mistake)
digging in viewport options has not helped much, but I was told to use volume visualizer with parameter “max vis res” which i have never used before…it really helps to adjust viewport representation of a volume
and another way of checking such situation is volume slice…
