[RESOLVED]usd_getbbox Vex functions return Huge incorrect values
   3585   5   1
I'm running into a small problem trying to automate a Daily Tool.
Basically I want to be able to get the BBox of my asset to transform them accordingly next to each other for presentation.
Only Problem is when I query the Bbox_size or min,max,etc… using the Vex functions(usd_getbbox_size)
houdini returns values that are huge (bboxSize = {-6.80565e+38,-6.80565e+38,-6.80565e+38}).
Which makes it basically unusable.
I don't know wether it's a bug Or I'm using it wrong.
Strangely enough inside my scene graph details window the world bounding Box property, shows the correct information…
If there is another way of obtaining this info (using python) I'm all ears
Thank you very much in advance!
Antonino
Here is my vex snippet:
//=========== Parameters =============//
string parentPath = usd_parentpath(0, @primpath);
//———– String Path Par
string wildCardAsset = “/cube1”;
//———– Setting Bbox Par
vector bbox_size = usd_getbbox_size(0,wildCardAsset,“Render”);
printf(“bboxSize = %g”,bbox_size);
Edited by NinoS - Nov. 20, 2020 06:59:21
usd_getbboxsize.hipnc (63.7 KB)
Ok so thanks to having a fresh head in the morning,
I found out that my “purpose” tag was wrong, and when it is it basically returns the world bounds I guess…
But switching to proxy made it work and the correct Bounding Box size is now returning!
YAY
I'd be interested to know how to access the World Bounding Box attr of say, a camera using VEX
not resolved here, same issue.
opened your .hip file, changed it to "Proxy" and still get same error. Was there something else you set to make it work?
I get same error with all the usd bbox functions
Edited by GrahamDClark - March 24, 2023 01:27:41
Screenshot 2023-03-24 012703.png (77.7 KB)
Yay! I'm certified! https://media.sidefx.com/uploads/accounts/badges/certified_instructor_badge_AkLiM3h.svg [media.sidefx.com]
The purpose name for proxy purpose is "proxy", not "Proxy". Also, make sure your mesh is in fact proxy purpose. If it doesn't have an explicit purpose set, use "default" as the purpose string.
Thank you Mark, default works.
