Houdini - Akkanein - Questions and Tips
   3920   10   1
Hello Guys, is there someone who can help me? I can say i'm beginner in Houdini, but i like this powerful software.
> I'm trying to remake this nice effects.
Your text to link here... [vimeo.com]
Video is little bit faster and it's better to slowdown, because you can see what i trying to achvie.
I read one interview where Albert Omoss talking he rebuild this code from Processing to Python in Houdini, but i dont find any tips how to make it or how i can rebuilt, what nodes i can use.
Thanks.
Edited by akkanein - June 16, 2021 14:36:23
Hey akkanein,
the video you linked contains something like a dozen of different effects. Which one do you mean?
CYTE
Hi CYTE, thanks for response, yeah in video is so much effects, my mistake that I didnt give more detailed information.
I post pictures for better understand what i mean. In my opinion it is the same setup for each other.
In last picture it's another style what i like. We can see nodes, but they are small. And i cant see what nodes he used.
Edited by akkanein - June 15, 2021 05:00:41
63fbe779727421.5cce272a178a2 (1).png (420.9 KB)
Hey akkanein,
as a starting point for the first three Images you posted:
take a grid set it to points.
use an attribute noise or attribute random to assign a Cd value to the points.
CYTE
Hey CYTE,
thank you for help. I appreciate that.
There was a fun thread on twitter recently about using simple (for coders) combinations of XOR and modulo operations to make cool patterns, here's the write up:
https://hackaday.com/2021/04/13/alien-art-drawn-with-surprisingly-simple-math/ [hackaday.com]
And I've attached a version in houdini.
Edited by mestela - June 15, 2021 17:16:41
patterns.hip (151.7 KB)
Hey mestela,
wow that is great, amazing how such a short code can produce such an complex pattern!
CYTE
Edited by CYTE - June 16, 2021 09:37:25
Hey Guys,
Thank you for your help.
I renamed this topic on my questions and tips, because i dont want post so many new topics.
I'm trying to rework one video tutorial from C4D
First steps was easy to made, but next steps are more complex.
For someone who looking for something similar i found nice tutorial.
int dim = sqrt(@numelem);
vector tp = set(@elemnum % dim,@elemnum/dim,0);
float size = fit01(rand(@elemnum),0.5,1);
int prim = addprim(0,"poly",addpoint(0,tp),
           addpoint(0,tp+set(0,size,0)),
           addpoint(0,tp+set(size,size,0)),
           addpoint(0,tp+set(size,0,0)));
float area = size *size;
setprimattrib(0,"area",prim,area);
node = hou.pwd()
geo = node.geometry()
geo1=geo
# Add code to modify contents of geo.
# Use drop down menu to select examples.
attrib = geo.addAttrib(hou.attribType.Prim,"sort_i",0)
def sa_kar(prim):
    return prim.attribValue("area")
lis = list(geo.prims())
lis.sort(key=sa_kar)
for i ,prim in enumerate(lis):
    s = node.inputGeometry(0).prim(i).points()[0].position()-prim.points()[0].position()
    for point in prim.points():
        pos = point.position()+s
        point.setPosition(pos)
play with this and make some noise..Have Fun
Conservation of Momentum
Hello Guys, it's possible to make this shape of laces?
