Control Frame Attribute in Partition
   2132   3   0
Would it possible to add a possibility to control frame attribute in the partition or any other way?
Because it causing an issue in the later PartitionByFrame operation when incorrect frame (just a first one) is coming from the upstream partition.
Edited by Ostap - July 7, 2021 05:12:35
pdg_frame_partition_.hipnc (157.3 KB)
Screen Shot 2021-07-07 at 9.10.53 PM.png (123.4 KB)
Hey Ostap, it should be possible to do that -- I can log an RFE for you.
Thank you!
Note:
Sometimes I'm not sure if my question is real RFE (to log it by myself) or something useful to discuss widely.
So my apologies if I'm doing it wrong.
There are some changes available in tomorrow's daily build that should help with that use case. Each partitioner node now has a parameter on the Advanced tab that can be used to control how the frame is set. You can choose to have the partitioner not set a frame at all, which I think will fix your use case. The partitioner can also be configured to set the frame to the largest or smallest frame from items in the partition, or the frame from the first or last work item.
