Hi!
I recently upgraded to 19 and since then, I keep getting some weird result from redshift renders.
I'm using aces1.2 as I did with 18.5 (no errors then) but maybe I forgot a step or something but in 19, I keep getting this message.
"failed to get ACES- ACEScg -> ACES 1.0 SDR-video(sRGB) processor from OpenColorIO config"
I have ocio pointing in env(also tried system variable method but no luck), confirmed the color setting in houdini is also pointing to that same config file.
Has anyone come across the same error message?
Please help!!
Help with OCIO
3199 1 0-
- joonsetsfire
- 8177 posts
There's no such space as "ACES 1.0 SDR-video" in the standard ACES 1.2 config. Looks like Redshift expects to be used with its bundled configs only.
https://docs.redshift3d.com/display/RSDOCS/Color+Management+-+OCIO+ACES [docs.redshift3d.com]
The naming of spaces used by the built in config different that the standard used by ACES 1.2 according to this.
