In H19, as soon as I click on a bezier controlpoint (or on the line connecting the point and the handles) it snaps to the axis of whatever viewport I select it in (or in case of the perspective viewport, it snaps to the nearest axis).
Is this a bug or the way it's supposed to work - or am I missing a setting? It makes the new curve tool completely useless!
(To be sure: I don't have any snapping on)
Checked in H19.0.383 and 19.0.455, both python2 and 3 versions
Regards, Jasper
New curve tool in H19 problem with editing bezier curves
2259 3 2-
- druitre
- 65 posts
- CYTE
- 802 posts
- druitre
- 65 posts
Hi CYTE,
it does change the behavior a bit when manipulating from perspective view - not completely snapping to an axis now, but still jumping away from position. When manipulating from side/front/top view, it still snaps.
What seems to work correctly is: Pick mode to View plane, hit 'k' (to see transform handles), then use those to position.
But now another problem arises: I can only select points in front view, the other three don't respond.
- CYTE
- 802 posts
