I'm using the instancer node with "reference" option to instance a bunch of animated references (not the "instancable reference" option due to buggy variants and disappearing geo), and need to offset the animations randomly. Cannot figure out a way though.
- The "retime instances"-node does not work if "reference" was selected in the instancer.
- Using a for-each loop with a "time shift"-node works but is extremely slow to use as it evaluates every frame.
- I'm also not able to use "edit property" to change the prototype "frame offset" in the reference node, as there is none in the USD schema.
I feel I am missing something obvious here? Is wrangle the way to go perhaps?
Time offset for instanced "references" not working (well)
3411 3 2-
- AndreasWeidman
- 129 posts
- Enivob
- 2658 posts
In the past, I have done this by making sure my animated instance was a mesh sequence. Then the task becomes constructing an s@instancefile attribute that references the files on disk. Each point can have its own temporal offset associated with it. Look that up inside the instancer, and construct your per-frame s@instancefile attribute based on that number and the current frame.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- AndreasWeidman
- 129 posts
- martinkindl83
- 287 posts
