I am starting to develop Houdini Engine tools that can work in multiple dccs (3dsmax, maya, ...). The houdini engine implementations treat the world transforms differently for different dccs (maya and max are different). There are also some differences with visualization of vertex colors etc.
Ideally there would be a way to find out which host dcc the plugin is running in. I can make a checkbox/dropdown where the user can specify that in the interface for now, but this feels like something I should be able to automate.
Does anyone know of a command or env variable that would allow me to query which host dcc I am running the Houdini engine plugin in?
I've tried looking in the docs for a while, but could not really find anything there.
Peter
Houdini Engine and querying which is the host dcc
7093 10 0-
- pclaes
- 257 posts
https://www.linkedin.com/in/peter-claes-10a4854/ [www.linkedin.com]
- johnmather
- 679 posts
- pclaes
- 257 posts
Great! I will try that out.
Thank you!
Thank you!
- Jose Miguel Casas Pagan
- 4 posts
is it possible to query the HAPI_CLIENT_NAME in maya? Im trying to reach info from the License server admin for the tool im creating in maya using python.
I would like to know if there is a houdini engine license available, list the users etc
Could a reach this info before loading the hda with python?
# Warning: Could not load OTL file: C:/0_ART/PRGMayaTools/houdini/hda/VertexHeatmap.hda Attempting to instantiate asset anyway. # # Warning: HAPI Error: No Valid Licenses Found - HAPI_LICENSE_MODE unset or is set to 'default' meaning Houdini Engine will first try to acquire a Houdini Engine license and if one is not found it will try to acquire an interactive Houdini license (Houdini Core then Houdini FX). - No Houdini Engine Indie license found. - No Houdini Engine license found. - No Houdini license. - Found a Houdini FX (Houdini Master) license but it is not the required commercial variant. - No Houdini Indie license. # // Error: Could not instantiate asset: Sop/VertexHeatmap in OTL file: C:/0_ART/PRGMayaTools/houdini/hda/VertexHeatmap.hda // // Error: HAPI Error: No Valid Licenses Found - HAPI_LICENSE_MODE unset or is set to 'default' meaning Houdini Engine will first try to acquire a Houdini Engine license and if one is not found it will try to acquire an interactive Houdini license (Houdini Core then Houdini FX). - No Houdini Engine Indie license found. - No Houdini Engine license found. - No Houdini license. - Found a Houdini FX (Houdini Master) license but it is not the required commercial variant. - No Houdini Indie license. //
Edited by Jose Miguel Casas Pagan - Feb. 3, 2022 05:08:04
- MaGiiCall
- 6 posts
- johnmather
- 679 posts
You can get the HAPI_CLIENT_NAME in your HDA by putting down a Python SOP and entering the following:
For Maya, this will always be "maya".
You can get the list of available Houdini licenses by running the following in Maya:
A license is pulled when you instantiate the first HDA in Maya. If you want to check that a license is available before creating it, you must query the license server yourself and stop the creation of the node if one does not exist. The best way to do this would be to create a shelf that would perform the license check and only create the nodes if one is available.
import os print('HAPI_CLIENT_NAME:', os.environ.get('HAPI_CLIENT_NAME'))
from maya import mel licenses = mel.eval('system("$HFS/houdini/sbin/sesictrl print-license")') print(licenses)
Edited by johnmather - Feb. 3, 2022 12:45:04
- 4 posts
I have and hda asset in the scene and my license is available and this is the message. Also cannot find sbin/sesictrl in my system
system("$HFS/houdini/sbin/sesictrl print-license"); // Result: '$HFS' is not recognized as an internal or external command, operable program or batch file. // # Result: u"'$HFS' is not recognized as an internal or external command,\r\noperable program or batch file.\r\n" #
- johnmather
- 679 posts
- 4 posts
- johnmather
- 679 posts
- 4 posts
Found this
https://www.sidefx.com/docs/houdini/ref/utils/sesictrl.html [www.sidefx.com]
Thanks a lot it is a bit tricky to digest the info but works
Edited by Jose Miguel Casas Pagan - Feb. 8, 2022 11:16:12
