I made a sphere with lower resolution, 64, and higher resolution, imagine 1024, then used the higher resolution to create a curve shape using Point Wrangle and then merged both.
The problem is using a poly bridge to create the grey part, make a bumpy section as shown in the image. This grey part is edgy and not smooth in other 3d software like blender.
How to solve this issue?
I appreciate any idea.
How to have a smooth poly bridge transition.
2062 3 1-
- ali_sarlak
- 9 posts
- toonafish
- 562 posts
- ali_sarlak
- 9 posts
Thanks for your reply,
I don't think that problem is from blender normals. The problem is that I don't know how to have a gradient smooth transition from low res to high res. Furthermore, such a transition makes the total number of primitives higher.
I would appreciate it if you have any setup to share with me.
- Morphtek
- 21 posts
ali_sarlaksomething like this i believe would be awesome and probably easy to setup in houdini for a wizzard "
