I'm studying Houdini for some time and at this point i'm trying to create something with a little more complexity than the usual. This time, I have a pattern applied to a spherical cage and would like to add a distortion similar to the "liquify" filter from photoshop.
I've been experimenting with attribute vop but so far I couldn't get to the aesthetic that I'm looking for.
That said, is there a way or how to achieve a liquify effect on geo within Houdini? I'm attaching an image of the sphere that I created and the liquify effect that I'm looking for. Any suggestions would be appreciated.
This kinda thing? Basically setup colour noise so you can preview it easily, then push the shape around by the cross product of the colour and N, which will flow around the surface (to an extent, push it too far and it'll overly distort for non spherical shapes)
@mestela That was spot on! Exactly the effect I was looking for. I have been trying to create something similar by creating displacement based on noisy color and then the ray sop but your solution is way simpler and faster. Thank you so much for sharing the knowledge.
@cncverkstad your shader solution is pretty cool! Will definitely study that, I can already visualize some interesting stuff to do with it. Thank you for sharing.
