Option "Set as Default Scheduler" of "tractorscheduler" node was not set "tractorscheduler" , so I set the "Default Top Scheduler" in the "topgeometry" node directly to "tractorscheduler".
After setting the option, the error message "unknown pdg scheduler type:tractorscheduler" is displayed.
I added the tractor site package path to my PYTHONPATH environment.
Does anyone know about this issue?
Unknown PDG scheduler type: tractorscheduler ??
2572 4 0-
- m83studio
- 4 posts
- tpetrick
- 616 posts
This likely means that the Tractor Python library isn't loaded properly. You can verify that by opening a Python Shell in your Houdini session, and attempting to import one of the components of the Python module. For example, verify that import tractor.api.author succeeds.
Note that if you're using a Python 3 build of Houdini, you'll also need to use the Python 3 version of the Tractor Python API or it won't be possible for Houdini to import it.
Edited by tpetrick - Oct. 17, 2022 12:37:14
- m83studio
- 4 posts
tpetrick
Thank you. I set the path with tractor python3 aip, now Set as Default Scheduler Option works well.
However, another problem arose.
Any idea why this error is occurring?
/opt/hfs19.5/python/bin/python /core/tmp/houdini/test_render/31890/pdgtemp/scripts/pdgmq.py --xmlport 9012 --relayport 9013 --connectionfile /core/tmp/houdini/test_render/31890/pdgtemp/pdgmq_server.txt --start
PDG_MQ rf025 9012 9013
18:44:27: Message Queue Server Running
18:44:37: 0.0 mps, avg=0.0ms, max=0.0ms
File "/core/tmp/houdini/test_render/31890/pdgtemp/scripts/pdgmq.py", line 795, in <module>
Caught Signal 2, signalling child 19175
File "/core/tmp/houdini/test_render/31890/pdgtemp/scripts/pdgmq.py", line 784, in main
exit_code = _start_server(args.host, args.xmlport, args.relayport,
File "/core/tmp/houdini/test_render/31890/pdgtemp/scripts/pdgmq.py", line 731, in _start_server
relay_server_instance.handle_request()
File "/opt/hfs19.5/python/lib/python3.9/socketserver.py", line 294, in handle_request
ready = selector.select(timeout)
File "/opt/hfs19.5/python/lib/python3.9/selectors.py", line 416, in select
fd_event_list = self._selector.poll(timeout)
KeyboardInterrupt
Edited by m83studio - Oct. 20, 2022 20:52:16
- moonjonghwan
- m83studio
- 4 posts
