How to use the new component variant number mode?
   3128   6   0
How to use the new component variant number mode(19.5.403 Build)?I can' t figure out how to use one component geometry to get many variants?Any ideas?
Anyone?I can't get useful info on the help.
When the Component Geometry Variants node is in Number mode, it creates a context option @GEOVARIANTINDEX, which can be used in expressions in a variety of ways. In the attached example, I'm using it to drive which of my four boxes is not hidden by a Prune LOP.
component-variants-number-mode.hip (185.2 KB)
BryanRay
Thanks,so this index thing can’t work inside component geometry?That’s limited
There are likely thousands of ways the context option can be applied. Just because I don't mention one specific application doesn't mean that it's impossible. Here's another example, this time with @GEOMETRYVARIANTINDEX controlling which rock is being imported to the Component Geometry node from the /obj network.
component-variants-number-mode_v02.hip (267.7 KB)
Thanks!I got it.
BryanRay
Hello! Thank you for your file! What should I write in the Number of Variants field to automatically get the number of variants in the Geometryvariants component?
