Change vertex number to point number
   3425   4   0
This might be a very easy problem to solve, but I just can't think of the solution. All I want to do is to just change the vertex number according to the point number. So, for example, in the following attached spreadsheet, I have vertex 0:0 and 0:1 with point number 1 and 0 respectively. I want to change the vertex number so that point number 0 would have vertex 0:0 and point number 1 would have vertex 0:1. I don't want to change the point number as they are in the correct position. Thanks is advance!
P.S. This is a moving point, and their vertex number keeps changing. So, using a reverse SOP would not fix the problem.
Edited by martinalex - Dec. 4, 2022 03:54:25
Screenshot 2022-12-04 154044.png (2.2 KB)
Vertex order depends on the topology of your geometry
You can use Rewire Vertices SOP to attach vertices to specific points using an attribute value
Which would obviously change the topology, so it really depends on why you need to do this
Since chances are you don't unless you are really after changing the topology of your geo
CG Supervisor
Framestore, NY
tamte
Hi Tamte! Thank you for the reply. I tried your solution, however, it seems that the problem still occurs. Perhaps, it is better for me to explain on what I want to achieve first. So, what I did here is that I used Boolean SOP on a given geometry (object_merge3) with a Grid. I used the abseams from the boolean operation to get the polyline on which later I would use the Sweep SOP to create a box. However, if I move the grid position, sometimes the vertex order changes. That is why I need a consistent vertex order so that I do not need to keep manually reverse the cross sections from the sweep node.
I don't see why wouldn't rewiring work in your case
since you are saying that the point numbers are in order as you expect
do this in Vertex Wrangle:
i@rewire_to = @vtxnum;
and then append Rewire Vertices SOP
assuming you have an open curve with same amount of points, then it should reorder vertices exactly based on point order
if you need to handle closed curves etc it's just a little bit more code, but should be straightforward
But if you tried this and it doesn't work for you post a file rather than screenshots
CG Supervisor
Framestore, NY
tamte
Ah, my apologies. It would appear that I misused the Rewire Vertices SOP. Yes, it is working properly now. Thank you so much for the help.
