Hello, I’m trying to set up a python node that only runs it’s script when a run button is pressed.
The only thing preventing me from making it work is that the button doesn't seem to set a 0 or 1 value for when its pressed.
I’ve tried setting status to 1 using hou.setenv("status",1)
and then read it in the script using hou.getenv("status")
But that didn`t seem to work.
Make a button paramater set value to 1 while clicked ?
1960 5 0-
- NicTanghe
- 244 posts
- SWest
- 313 posts
- NicTanghe
- 244 posts
THis throws me the error
I’m also a bit confused, wouldn't I need to use.
('python') if I want to use the normal python script ?
Ps.
I whould think
whould be the propper formatting ?
AttributeError: 'dict' object has no attribute 'parm'
Ps.
I whould think
__import__ (kwargs.parm('python'));main()
Edited by NicTanghe - Jan. 10, 2023 16:20:45
- SWest
- 313 posts
If you just want one or a couple of run buttons and then some python code it is possible to simply attach this to a null. Probably you could attach it to any subnetwork or HDA as well (I've not really been trying this though).
- SWest
- 313 posts
If you need to set values accessible from any node, without keeping track of paths to nodes, you could do something like:
def a(): hou.session.my_value=1 def b(): hou.session.my_value=0 try: print(hou.session.my_value) except: pass
- NicTanghe
- 244 posts
