Double Mesh simulation using vellum pack / unpack ?
2306 8 1-
- _Christopher_
- 767 posts
- 9417 posts
- _Christopher_
- 767 posts
- 9417 posts
- _Christopher_
- 767 posts
- 9417 posts
_Christopher_It probably is, I assume you can do it like that, I just haven't tried, so it's just a theory, but don't see why it wouldn't worktamte
In theory it's possible to merge 2 constraint streams if you rewire all vertices to just one set of points, and delete the other
It's not possible in practice ?
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- _Christopher_
- 767 posts
tamte_Christopher_It probably is, I assume you can do it like that, I just haven't tried, so it's just a theory, but don't see why it wouldn't worktamte
How would I do this as you mentioned ?
【T】【C】【S】
- 9417 posts
I just tried and it works as described
one possible issue is that Vellum Constraint can also alter the geometry output and modify attributes like pscale, mass, volume
so merging just constraint outputs will miss those
but to properly merge those may be tricky as you may not know which points were altered and if the change is desirable since geo points are shared among all constraints
but if your workflow assumes that pscale and mass will be properly set by the main stream then you may be mostly ok and then just identify whats missing as you go
that all being said threat this just as an interesting exercise rather than a workflow
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- _Christopher_
- 767 posts
