Set Attribute Value based on ID when PTNUM change VEX
   2306   1   1
i do a FLIP Sim and delete all Particles below the Bounding region, because the simulation is much faster and i dont need them. I create the ID attribute in the flip solver.
After the DOP/FLIP Simulation in SOP Context, i would do the shrink pscale when the points are not in a Volume(VDB). So i create a Mask attribute with volumesampe and this works fine. (mask=1 when outside, maks = 0 when inside the volume.)
The shrink calculation i would do in an SOP Solver. The Problem i have is the changing PTNUM.
I dont`t get it, how to set the new calcutaed pscale attribute based on the ID in an Point Wrangle.
MANY THANKS
if you want to get attribute by id (default) from second input you can just do
f@mask = f@opinput1_mask;
that would however set attribute on points that don't find corresponding id in second input to 0
so if you for example want to preserve input value for points that don't find match you can do
int pt = idtopoint(1, i@id);
if (pt != -1) {
    f@mask = point(1, "mask", pt);
CG Supervisor
Framestore, NY
