Adding different materials to separate instancers HDA
   2350   1   0
I have three sets of points in Houdini (19.5.605), each instancing stadium seats in unreal(5.2). The "unreal_split_attr" successfully separates the points by material into three distinct instanced static mesh components however they all have the first material assigned to them.
I have tried this same setup with "unreal_material_instance" as well as "unreal_materialINDEX" (both "unreal_material1", "unreal material2", "unreal material3" and using "unreal_material1" for all three).
How can I assign three separate materials on the separate instancers?
NOTE: using the material parameter attribute or making the material in houdini first is not an option as I also have 50 other materials for complex vertex animated people.
Edited by simonjohns - June 8, 2023 13:58:56
Screenshot 2023-06-06 10531+1.jpg (72.1 KB)
Screenshot 2023-06-06 1053593.jpg (91.6 KB)
Screenshot 2023-06-06 1053182.jpg (68.4 KB)
I've got exactly the same issue, have smbd solved it?
