I’m using the following vex to attempt to create a Min max controller with selecting specific polygon sizes and outputting a group from this. But it’s not working and I’m not sure if I’m writing this wrong or not. Thoughts?
float minSize = ch("min_size", 0.1);
float maxSize = ch("max_size", 0.2);
if (@area >= minSize && @area <= maxSize)
setprimgroup(geoself(), "selected_polygons", @primnum, 1);
else
removeprimgroup(geoself(), "selected_polygons", @primnum);
vex that selects polygon size
2143 8 0-
- luidox
- 36 posts
- freshbaked
- 153 posts
luidox
else
It works fine if you remove those lines. The removeprimgroup function only takes 2 arguments but I'm not sure why you're using that function anyways...
Also wrangles won't show group highlighting unless you type the group name in the Output Selection Group parameter under the bindings tab!
Edited by freshbaked - Sept. 23, 2023 18:21:54
- luidox
- 36 posts
- animatrix_
- 5130 posts
Here is one way:
float minarea = ch("min_area"); float maxarea = ch("max_area"); float area = primintrinsic ( 0, "measuredarea", @primnum ); if ( area >= minarea && area <= maxarea ) i@group_prims = 1;
- luidox
- 36 posts
- animatrix_
- 5130 posts
luidox
In this case your using a measure node?
No. I am just checking the area using the primitive intrinsic attribute called "measuredarea".
- freshbaked
- 153 posts
- luidox
- 36 posts
- freshbaked
- 153 posts
