Hi, I wanted to animate a point moving on a zig-zag path at constant speed and later attach a line (with 2 points) to that animated point to simulate an antenna of a car.
The main problem is the animation of the point following the path. I can see the velocity is a bit chaotic. It's not much but when I simulate the antenna, it's super obvious. To give an exemple here are velocities 3 frames in a row:
f66 v13.8136
f67 v14.0461
f68 v13.5684
To make the point animation, I did these steps:
1. create a zig-zag curve
2. resample with Treat Polygons As Subdiv Curves
3. Carve sop with First U animated from 0 to 1 (constant anim curve)
4. Create point that always gets its position from point Zero of the carve curve
What should I do to get a smooth anim?
Point following path: very chaotic speeds?{[SOLVED]}
2120 6 0-
- olivierth
- 1193 posts
- Enivob
- 2659 posts
- olivierth
- 1193 posts
- Tanto
- 550 posts
- olivierth
- 1193 posts
I used you logic but kept the carve sop. That way, I can still use a graph editor to modify the animation speed. I end up with a very smooth animation. The velocity looks good (doesnt change too much from frame to frame).
BUT! I noticed another problem. My line (the antenna) has a smooth animation. The X and Z positions are animated but Y stays at zero for the whole anim but after the vellum solver, I can see the root point jumping up and down on Y axis. It's like the vellum solver sop is not precise.
Any idea how to solve that?
- olivierth
- 1193 posts
- olivierth
- 1193 posts
