Hi everyone,
I'm busy with some render engine RND atm and utilizing the "Collect" node in order to setup multiple engines shaders at the same time.
However I noticed with Houdini 20 that when dropping down a "Karma Material Builder" it automatically has 3 outputs (surface, displacement and properties) but the Collect node only accepts one "shader" input for the material.
How does this new "Karma Material Builder" work in conjunction with the "Collect" node?
How do I have both surface and displacement plugged into the Collect?
Thank you!
amwilkins
Karma Material Builder plugged into Collect node
2032 2 0-
- am_wilkins
- 27 posts
- rafal
- 1471 posts
Usually, you can just connect the shader outputs to the Collect inputs.
This should produce a USD Material primitive with several terminal outputs uniquely identifying shader type (surface vs. displacement) and shader context (karma vs mtlx).
token outputs:kma:displacement.connect = </materials/collect1/karmamaterial.outputs:displacement>
token outputs:kma:surface.connect = </materials/collect1/karmamaterial.outputs:surface>
token outputs:mtlx:displacement.connect = </materials/collect1/mtlxmaterial.outputs:displacement>
token outputs:mtlx:surface.connect = </materials/collect1/mtlxmaterial.outputs:surface>
- am_wilkins
- 27 posts
