Texture look like Premultiplied
   1460   3   0
The second one doesn't have an alpha channel。
Is there any way to turn it off?
Are you trying to disable alpha premultiplication in the 3d viewport? I don't think it's possible.
jsmack
This is the result of rendering.
Disabling it in the 3D view doesn't seem to work, or maybe I haven't found the corresponding switch.
I find out that you should unpremult the color you get like this:
path = r"you/image/path";
vector4 cd = texture(path, v@uv.x, v@uv.y, "srccolorspace", "linear"); // note: always use linear
@Cd = cd;
@Alpha = cd.a;
if(@Alpha > 0){
    @Cd /= @Alpha; // unpremult
    @Cd = pow(@Cd,2.2); // if your color space is srgb, add this
And because the inner premult came before color space conversion, so you'd always sample it as linear, then unpremult, and finally convert to your color space like sRGB.
Edited by dolag233 - Nov. 4, 2025 02:03:32
