hello new person here hitting a bit of nube a wall. what would be the best approach for a slow motion cache that doesn't disrupt the simulation?
I've tried adjusting timescale within vellum solver both with and without substeps and then also various combinations of substep adjustment between the solver and the file cache...tried recording cache while timeline was at 120 FPS and then rendering back at 24FPS..
I thought I might have had it licked speeding up FPS and actually ended up with what looked like a great slow motion cache! unhappily still looks like a stop motion render out of karma once the .ext files are imported into davinci for regular 24fps playback.
clearly I'm doing it all wrong and am confused by the documentation re. retime node so any help at all would be most appreciated
cheers!
proper way to slow down vellum sim
1970 4 1-
- Shy1
- 27 posts
- Shy1
- 27 posts
- Tanto
- 543 posts
You seem to have adjusted the right settings, your options were slowing down the time scale, or caching the sim with subframes (you need subframes both in your solver and your file cache node) and retiming it afterwards. If you say you end up with the appropriate cache, maybe your problem is with DaVinci rather than Houdini? Have you tried viewing your render in mplay?
Edited by Tanto - May 17, 2024 10:00:20
- Shy1
- 27 posts
@Tanto thanks for responding.honestly I'm completely stumped. it's not davinci because I export in the same way there all the time with no issues. have several renders from the same project working fine.
for some reason this particular simulation seems to be causing this flickering on the material and I don't understand why.
I've tried..
no time alteration at all
no sub divisions
no cache
different materials
simplified collision geometry
can anyone help me identify the issue in the attached mp4? I'm sure I must be overlooking something quite straightforward
I've tried..
no sub divisions
no cache
different materials
- Shy1
- 27 posts
