APEX Rigging Tutorial | The Reverse Foot
   2829   2   2
This was probably the most requested video since I started making these, so here you go -> https://www.youtube.com/watch?v=NJAuTazoKaE&ab_channel=maxrose [www.youtube.com]
Any questions, let me know!
-max
1. How do you load the simplelook node? Even after restarting houdini it's not there for me
2. Also, did you use the actual simpleLook node in the graph or was it just floating there to show that it works?
I contribute to the beauty of this world
https://houdininotes.ivanlarinin.com/ [houdininotes.ivanlarinin.com]
1. You have to make sure that you save the subgraph into the correct folder:
/user/Documents/Houdini20.0/apexgraph/ (this is where you put your subgraphs)
2. When I'm creating the component script, I pull in the simplelook node as a reference only. It doesn't get used in the final rig graph.
