Viewport Color Editor not loading
   2182   9   0
Greetings wizards!
Two things I'd like to bring up:
1) The Viewport Color Editor doesn't seem to want to load from the help files. How can this be fixed/loaded?
2) Is there a way I can add a new preset to the Color Scheme list when going to Display Options --> Background so I don't have to overwrite the default schemes?
Edited by frescalus - Dec. 6, 2024 12:43:30
-----Neil
1) A workaround for this could be to use a module that loads examples from the help.
__import__('houdinihelp').load_example("/examples/python_panels/viewportcoloreditor.pypanel")
2) I've thought about this too but there doesn't seem to be a way to add new colour schemes.
Edited by dtempcyer - Dec. 7, 2024 04:37:32
alexwheezy
Hi Alex,
I can't seem to use that command. I've tried it in the Python Shell and the Python Source Editor, nothing happens.
-----Neil
frescalus
Hi Alex,
It should work. Try opening the Python Panel additionally.
Edited by dtempcyer - Dec. 7, 2024 10:53:04
alexwheezy
Odd, nothing is popping up in the shell when I hit apply.
I did, however, get it to work in the panel so I think I'm good...just odd that I can't get a separate window to pop up.
Thanks for the help!
-----Neil
The other thing that's odd is that it doesn't list all of the items in the drop down that are in the Display Options.
-----Neil
This tool appeared earlier than other schemas and if you open the source code directly in the toolbar you can see how it adds these schemas.
self.mySchemeMenu.addItem("Light", "config/3DSceneColors.light")
self.mySchemeMenu.addItem("Dark", "config/3DSceneColors.dark")
self.mySchemeMenu.addItem("Grey", "config/3DSceneColors.bw")
Edited by dtempcyer - Dec. 7, 2024 11:27:24
alexwheezy
Thank you, and I do see that and it lets me add items there, hopefully a dev could respond on how to get it in the Display Options list on the background tab. I've been searching files, but I can't seem to find anything that relates to that.
The documents show a module hou.viewportColorSchemes, so I'm curious where this lives.
Edited by frescalus - Dec. 9, 2024 08:54:52
-----Neil
This scheme can be found in the configuration files: $HFS/houdini/config/3DSceneColors.dg
alexwheezy
Yeah, I know that...I'm talking about adding a new scheme to the list. I'm hoping someone from sidefx can say how to add to the list.
-----Neil
