Is there any way to store last modified translate parm value
1146 2 1-
- GreenPitaya
- 44 posts
- vikus
- 247 posts
Unfortunately there are no OnReleas, OnPress parameter events to store the last parm value. But you can compare time delta(cached/current time) with a tolarance value, which is not perfect but gives you a similar effect.
In the hip / embedded hda / scripts / python module you will find a constant MAX_TIME_DELTA, which is the tolarance value in milliseconds. Currently it is set to 300, you can play with it to find a sweet spot that might work for you.
If you more up to get distance while moving something in the viewport you can impliment hou.ViewerDragger [www.sidefx.com]. See drag_delta.hip example.
- GreenPitaya
- 44 posts
vikusThank you very much!
In the hip / embedded hda / scripts / python module you will find a constant MAX_TIME_DELTA, which is the tolarance value in milliseconds. Currently it is set to 300, you can play with it to find a sweet spot that might work for you.Image Not Found
If you more up to get distance while moving something in the viewport you can impliment hou.ViewerDragger [www.sidefx.com]. See drag_delta.hip example.Image Not FoundImage Not Found
I'll try it!
