"Frame Selected"(F key) doesn't work in Solaris context?
   4730   9   3
I have a simple object imported by Scene Import LOP. In /obj context, when I select it and press F, the viewport correctly focus on the object:
But in /stage context, when I press F, it seems to focus on the whole scene or something:
Is it intentional? Is there any reason that it doesn't focus on the selected object, just like in /obj context?
Screenshot 2021-11-29 023741.png (651.3 KB)
Screenshot 2021-11-29 023802.png (734.5 KB)
This works alright for me... Could you submit a bug with a hip file? Also, make sure you've got the latest daily build of H19. Thanks!
mtucker
It doesn't work with a non-HoudiniGL delegate though.
Edit: oddly enough, it's working for me with a trivial single prim scene in build 455, but I assume this is just a fluke as it's never worked for me before.
Edit2: nevermind, the problem is it only works with component primitives. It fails to home on leaf prims.
Strange, changing the prim back to a component, and it still fails to home, even though it was working before I switched the kind to none.
Edited by jsmack - Dec. 1, 2021 12:20:31
It's not component vs leaf, because my test didn't have any kinds set anywhere. So maybe the bug report isn't so much a hip file as a list of instructions to reproduce...
Did you ever find a solution to this?
Trying to make some sense of this...
Space F only frames the entire scene rather than the selected node
Using the viewport drop menu the Home selected and Frame selected entries work correctly - but only if the Handle mode is enabled!
This is driving me nuts. F frame the entire scene, rather than the selected node. Still... 2025, no one found a work around or fix for this?
Houdini Indie 18
Win 10 64-bit
Please make sure that you have selected the object(s) of interest in the Scene Graph before framing.
Yes, object is selected in Scene Graph. Still doesn't work.
Houdini Indie 18
Win 10 64-bit
agree this seems wonky. for me spacebar+F frames selected. one major difference to sops vs lops is that in sops, you can select the node in the network view. In lops, that's not the case and you either need to select the object in the viewport or the scene graph. but in those cases spacebar+F does frame the object for me.
