Hello All,
Is there anyone who has been through the process
of installing Renderman for Houdini on Mac OS.
If you're out there would it be possible to connect
so as to highlight where I seem to be going wrong.
Thanks in Advance
LeSouf/Houdini Trainer
as the attached image shows Arnold & 3Delight for Houdini are both recognised
PR_RenderMan for Houdini 21.0.671
3274 4 1-
- LESOUFLESOUF
- 4 posts
- TheNotepadShow
- 113 posts
Hey Lesouf,
My name is Todd Manus, I don't have a Mac, but I'll see if I can help. With Linux and Windows 11, you can simple copy of a JSON file over from where Renderman got installed, to a folder called packages that is usually in your "houdini21.0" home folder
See the packages installation section here: https://rmanwiki-27.pixar.com/space/RFH27/544640398/Installation+of+RenderMan+for+Houdini [rmanwiki-27.pixar.com]
If you have question, I can try and help. You can reach me on Pixar's Renderman Discord server.
BTW, I have never seen the Renderman plugin in the Labs/Packages section ever, so I don't think you have to worry to much about the fact that it doesn't show up there.
Edited by TheNotepadShow - April 20, 2026 10:27:41
- LESOUFLESOUF
- 4 posts
- TheNotepadShow
- 113 posts
- LESOUFLESOUF
- 4 posts
