Hi !
wanted to try Houdini Apprentice but no luck with install/running.
WinXP SP1,P3/733Mhz/512MbRam/GF2/plenty of HD space
Network (TCP/IP) running flawless
i ‘ve seen the problem in an older thread before,
and there was no solution. I’m a tech-wiz believe me- so please no basic tips about wrong configured services or something -
heres the problem:
During install ( near the end of it, tried standalone/network already ) the 2 houdini services get started
(sesinetd.exe and hserver.exe) sesinetd runs perfect, hserver.exe crashes after about 6 secs. with Div by zero - see crash-dump below)
this behaviour is consistent and i tried to deinstall/reinstall houdini a hundred times - no luck - t.
everytime hserver-service is started (manual or automatic it crashes)
I really can't believe such a basic flaw can slip through the testing-cycle
i mean div-by-zero is the most basic programming error that can happen, even if hserver doesn't like my hardware/software config there seems to be no error-checking in the code ?!??
So - is there a know solution ( an update-patch ) maybe ? or should i drop my interest in houdini, (using Max in my Job) , cause of this ?
And please don't tell me to switch to Linux ;-? it's better i know but this is no option for me ;-)
greetings & thanks in advance
P.S: here is a part of the crash dump and the codeline causeing the crash is marked with “FAULT”
0044a292 83d800 sbb eax,0x0
0044a295 8944241c mov ,eax
0044a299 89542418 mov ,edx
0044a29d 0bc0 or eax,eax
0044a29f 7518 jnz hserver+0x4a2b9 (0044a2b9)
0044a2a1 8b4c2418 mov ecx,
0044a2a5 8b442414 mov eax,
0044a2a9 33d2 xor edx,edx
FAULT ->0044a2ab f7f1 div ecx
0044a2ad 8bd8 mov ebx,eax
0044a2af 8b442410 mov eax,
0044a2b3 f7f1 div ecx
0044a2b5 8bd3 mov edx,ebx
0044a2b7 eb41 jmp hserver+0x4a2fa (0044a2fa)
0044a2b9 8bd8 mov ebx,eax
0044a2bb 8b4c2418 mov ecx,
0044a2bf 8b542414 mov edx,
0044a2c3 8b442410 mov eax,[esp+0x10
Hserver keeps on crashing (Div by Zero)- even during install
15416 14 2-
- JoeFrog
- 7 posts
- stevenong
- 1634 posts
- JoeFrog
- 7 posts
thanks for the quick response…
and after reading my post again - i feel sorry that it sounds
a little aggressive - i wrote it directly after hazzling around with the hserver-service -
so this aggression goes against the technical problems -
not you or anyone from the sidefx/houdini guys ;-)
sorry and thanks again ;-)
- lucas
- 269 posts
- JoeFrog
- 7 posts
- lucas
- 269 posts
Perhaps the problem has been fixed in a later version of Houdini. Could you please try downloading and installing Houdini 6.0.340 from http://www.sidefx.com/dls [sidefx.com] ?
- JoeFrog
- 7 posts
thanks for the tip - but same effect.
after searching previous posts i found a thread by a user who has EXACTLY (point for point ) the same problem
http://www.sidefx.com/forum/viewtopic.php?t=431&highlight=hserver [sidefx.com]
diagnostic outputs says local IP (and Server IP) is 127.0.0.1
which houdini doesn't like ( but should work technicaly cause this addy is
localhost )
but i'm not sure if hserver crashes because of the 127.0.0.1 it asumes for
the local IP….
UPDATE:
the crash is not from the 127.0.0.1 IP , it's another problem, if i enter my IP directly in the license-admin it get reflected in the diagnostic output ( no more standalone mode though )
the problem is THE CRASH of hserver.exe
localhost )
the local IP….
UPDATE:
- lucas
- 269 posts
- JoeFrog
- 7 posts
Okay - here we go again,
This time it's a different WinXP Pro installation,without the tweaks and disabled services
a serious user must perform, to deactivate all the nonsense running on XP by default……
This is pretty plain after setup and without XP SP1 - but not even i did
expect it - shows the same thing.
I repeat my stats on this Test:
Hardware:
……P3/733Mhz, Asus P3B-F, 640MB Ram,
……Asus V7700 GF2 GTS Dlx,
……Drives C,D,E,G,H,K, all NTFS, all at least 1 GB free
……DVD (O
; CDRW (P
..PCI:
……3C900 Networkcard,Creative SBLive,HPT 370 Raid,
……Firewirecontroller (TI Chip)
Software:
……WinXP Prof. US-english, System-Drive is E: (other tests was C
……ServicePack: NONE
……mostly plain install from the CD and no major updates since
……(IE6 or DirectX untouched)
……Network set to TCPIP, DHCP enabled, no firewall,
……Client for Microsoft Networks,File & PrinterSharing, QoS Service
……are NOT activated for this network, ( makes no difference - tested !!)
On this system i started the Houdini 6.0.340 setup,
same effect, near the end hserver.exe got launched
and crashed, a second try with manual launch shows the same.
So thats all i can give you - i stop for now.
At the end of the post you find all the drwatson-output from the 2 crashes,
hope it helps you in your debugging (and no sensible information slips through with it ;-)
HEY !!! maybe you guys at sidefx could give me a new
job - cause the company i worked for has no money left to pay me ;-)
and dismissed me… ;-)
cheers and happy bug-hunting! - Joe
Microsoft (R) DrWtsn32
Copyright (C) 1985-2001 Microsoft Corp. All rights reserved.
Application exception occurred:
App: E:\WINXP\System32\hserver.exe (pid=1852)
When: 7/1/2003 @ 18:42:03.300
Exception number: c0000094 (divide by zero)
*—-> System Information <—-*
Computer Name: FRODOXP
User Name: SYSTEM
Terminal Session Id: 0
Number of Processors: 1
Processor Type: x86 Family 6 Model 8 Stepping 3
Windows Version: 5.1
Current Build: 2600
Service Pack: None
Current Type: Uniprocessor Free
Registered Organization: JWC
Registered Owner: JWC
*—-> Task List <—-*
0 System Process
4 System
388 smss.exe
452 csrss.exe
476 winlogon.exe
520 services.exe
532 lsass.exe
696 svchost.exe
752 svchost.exe
832 svchost.exe
856 svchost.exe
940 spoolsv.exe
1048 nvsvc32.exe
1084 svchost.exe
1108 vsmon.exe
1236 MINILOG.EXE
1496 Explorer.EXE
1692 ctfmon.exe
224 devldr32.exe
264 Houdini6_0_340.exe
284 msiexec.exe
112 IDriver.exe
1076 cmd.exe
1852 hserver.exe
1856 sesinetd.exe
728 gfont.exe
1412 drwtsn32.exe
*—-> Module List <—-*
(0000000000220000 - 0000000000230000: E:\WINXP\System32\MSVCIRT.dll
(0000000000400000 - 0000000000460000: E:\WINXP\System32\hserver.exe
(0000000071aa0000 - 0000000071aa8000: E:\WINXP\System32\WS2HELP.dll
(0000000071ab0000 - 0000000071ac5000: E:\WINXP\System32\WS2_32.dll
(0000000071ad0000 - 0000000071ad8000: E:\WINXP\System32\WSOCK32.dll
(0000000076f90000 - 0000000076fa0000: E:\WINXP\System32\Secur32.dll
(0000000077c10000 - 0000000077c63000: E:\WINXP\system32\msvcrt.dll
(0000000077c70000 - 0000000077cb0000: E:\WINXP\system32\GDI32.dll
(0000000077cc0000 - 0000000077d35000: E:\WINXP\system32\RPCRT4.dll
(0000000077d40000 - 0000000077dcd000: E:\WINXP\system32\USER32.dll
(0000000077dd0000 - 0000000077e5b000: E:\WINXP\system32\ADVAPI32.dll
(0000000077e60000 - 0000000077f45000: E:\WINXP\system32\kernel32.dll
(0000000077f50000 - 0000000077ff9000: E:\WINXP\System32\ntdll.dll
*—-> State Dump for Thread Id 0x734 <—-*
eax=00043a7c ebx=00000000 ecx=0445fcc0 edx=00000000 esi=00000000 edi=0000003c
eip=7ffe0304 esp=0445fb90 ebp=0445fbf8 iopl=0 nv up ei pl nz na pe nc
cs=001b ss=0023 ds=0023 es=0023 fs=003b gs=0000 efl=00000202
function: <nosymbols>
No prior disassembly possible
7ffe0304 c3 ret
7ffe0305 9c pushfd
7ffe0306 810c2400010000 or dword ptr ,0x100
7ffe030d 9d popfd
7ffe030e c3 ret
7ffe030f 8bd4 mov edx,esp
7ffe0311 0f05 syscall
7ffe0313 c3 ret
7ffe0314 90 nop
7ffe0315 9c pushfd
7ffe0316 810c2400010000 or dword ptr ,0x100
7ffe031d 9d popfd
7ffe031e c3 ret
7ffe031f ff00 inc dword ptr
7ffe0321 0000 add ,al
7ffe0323 0000 add ,al
7ffe0325 0000 add ,al
7ffe0327 0000 add ,al
7ffe0329 0000 add ,al
7ffe0304 c3 ret
7ffe0305 9c pushfd
7ffe030d 9d popfd
7ffe030e c3 ret
7ffe0313 c3 ret
7ffe0314 90 nop
7ffe0315 9c pushfd
7ffe031d 9d popfd
7ffe031e c3 ret
7ffe032b 0000 add ,al
7ffe032d 0000 add ,al
*—-> Stack Back Trace <—-*
*** ERROR: Symbol file could not be found. Defaulted to export symbols for E:\WINXP\System32\ntdll.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for E:\WINXP\system32\ADVAPI32.dll -
WARNING: Stack unwind information not available. Following frames may be wrong.
*** WARNING: Unable to verify checksum for E:\WINXP\System32\hserver.exe
*** ERROR: Module load completed but symbols could not be loaded for E:\WINXP\System32\hserver.exe
*** ERROR: Symbol file could not be found. Defaulted to export symbols for E:\WINXP\system32\kernel32.dll -
ChildEBP RetAddr Args to Child
0445fb8c 77f7ef2f 77e78bf1 0000003c 00000000 *SharedUserSystemCall+0xc (FPO: )
0445fbf8 77de1052 0000003c 0445fcac 00000216 ntdll!NtReadFile+0xc
0445fc24 77de0f00 0000003c 0445fcac 00000216 ADVAPI32!RegisterServiceCtrlHandlerW+0x1b5
0445fc90 77de1f2e 0000003c 0445fcac 00000216 ADVAPI32!RegisterServiceCtrlHandlerW+0x63
0445fec4 0041ce27 0000003c 00457e94 0041ce30 ADVAPI32!StartServiceCtrlDispatcherA+0x71
0445ffc0 77e7eb69 77dd1a6b 00000000 7ffdf000 hserver+0x1ce27
0445fff0 00000000 0044a10f 00000000 00000000 kernel32!CreateProcessInternalW+0x1177
*—-> Raw Stack Dump <—-*
000000000445fb90 2f ef f7 77 f1 8b e7 77 - 3c 00 00 00 00 00 00 00 /..w…w<…….
000000000445fba0 00 00 00 00 00 00 00 00 - c8 fb 45 04 ac fc 45 04 ……….E…E.
000000000445fbb0 16 02 00 00 00 00 00 00 - 00 00 00 00 58 fc 45 04 …………X.E.
000000000445fbc0 82 8b e7 77 ac fc 45 04 - 00 00 00 00 1b 9e e7 77 …w..E……..w
000000000445fbd0 70 3a 04 00 18 3f 04 00 - 00 00 00 00 00 00 00 00 p:…?……….
000000000445fbe0 bc fb 45 04 7c 3a 04 00 - 80 fc 45 04 86 bb e9 77 ..E.|:….E….w
000000000445fbf0 e8 8c e8 77 ff ff ff ff - 24 fc 45 04 52 10 de 77 …w….$.E.R..w
000000000445fc00 3c 00 00 00 ac fc 45 04 - 16 02 00 00 20 fc 45 04 <…..E….. .E.
000000000445fc10 00 00 00 00 70 3a 04 00 - 18 3f 04 00 00 00 00 00 ….p:…?……
000000000445fc20 00 00 00 00 90 fc 45 04 - 00 0f de 77 3c 00 00 00 ……E….w<…
000000000445fc30 ac fc 45 04 16 02 00 00 - 58 fc 45 04 6b 1a dd 77 ..E…..X.E.k..w
000000000445fc40 01 00 00 00 00 00 00 00 - 7c fc 45 04 44 07 00 00 ……..|.E.D…
000000000445fc50 01 00 00 00 00 00 00 00 - 00 00 00 00 01 00 00 00 …………….
000000000445fc60 00 00 00 00 00 00 00 00 - 18 3f 04 00 70 3a 04 00 ………?..p:..
000000000445fc70 0d 0e de 77 c0 fc 45 04 - 3c fc 45 04 00 00 00 00 …w..E.<.E…..
000000000445fc80 b0 ff 45 04 c4 2e de 77 - f8 33 df 77 ff ff ff ff ..E….w.3.w….
000000000445fc90 c4 fe 45 04 2e 1f de 77 - 3c 00 00 00 ac fc 45 04 ..E….w<…..E.
000000000445fca0 16 02 00 00 00 f0 fd 7f - 01 00 00 00 34 00 00 00 …………4…
000000000445fcb0 51 00 00 00 00 00 00 00 - 14 00 00 00 00 00 00 00 Q……………
000000000445fcc0 48 00 6f 00 75 00 64 00 - 69 00 6e 00 69 00 53 00 H.o.u.d.i.n.i.S.
*—-> State Dump for Thread Id 0x744 <—-*
eax=00000001 ebx=00000078 ecx=0856f6ec edx=00000000 esi=00000000 edi=0856ff50
eip=7ffe0304 esp=0856ff10 ebp=0856ff68 iopl=0 nv up ei pl nz na pe nc
7ffe0304 c3 ret
7ffe0305 9c pushfd
7ffe030d 9d popfd
7ffe030e c3 ret
7ffe0313 c3 ret
7ffe0314 90 nop
7ffe0315 9c pushfd
7ffe031d 9d popfd
7ffe031e c3 ret
7ffe0304 c3 ret
7ffe0305 9c pushfd
7ffe030d 9d popfd
7ffe030e c3 ret
7ffe0313 c3 ret
7ffe0314 90 nop
7ffe0315 9c pushfd
7ffe031d 9d popfd
7ffe031e c3 ret
0856ff0c 77f7e76f 77e775b7 00000000 0856ff34 *SharedUserSystemCall+0xc (FPO: )
0856ff68 77e61bf1 000003e8 00000000 00408cbc ntdll!NtDelayExecution+0xc
00000000 00000000 00000000 00000000 00000000 kernel32!Sleep+0xb
000000000856ff10 6f e7 f7 77 b7 75 e7 77 - 00 00 00 00 34 ff 56 08 o..w.u.w….4.V.
000000000856ff20 e6 1b e6 77 90 7e 45 00 - 78 00 00 00 00 00 00 00 …w.~E.x…….
000000000856ff30 34 ff 56 08 80 69 67 ff - ff ff ff ff 14 00 00 00 4.V..ig………
000000000856ff40 01 00 00 00 00 00 00 00 - 00 00 00 00 10 00 00 00 …………….
000000000856ff50 20 ff 56 08 60 8c 40 00 - dc ff 56 08 86 bb e9 77 .V.`.@…V….w
000000000856ff60 30 21 e8 77 00 00 00 00 - 00 00 00 00 f1 1b e6 77 0!.w………..w
000000000856ff70 e8 03 00 00 00 00 00 00 - bc 8c 40 00 e8 03 00 00 ……….@…..
000000000856ff80 d8 7e 45 00 90 7e 45 00 - 48 7e de 77 0c 07 00 00 .~E..~E.H~.w….
000000000856ff90 56 cf 41 00 70 3a 04 00 - 00 00 00 00 70 3a 04 00 V.A.p:……p:..
000000000856ffa0 ec ff 56 08 01 00 00 00 - 1b 0e de 77 01 00 00 00 ..V……..w….
000000000856ffb0 78 3a 04 00 00 00 00 00 - ed 02 e8 77 70 3a 04 00 x:………wp:..
000000000856ffc0 00 00 00 00 00 00 00 00 - 70 3a 04 00 00 00 00 00 ……..p:……
000000000856ffd0 00 d0 fd 7f c0 ff 56 08 - 07 00 00 00 ff ff ff ff ……V………
000000000856ffe0 86 bb e9 77 80 5b e9 77 - 00 00 00 00 00 00 00 00 …w.[.w……..
000000000856fff0 00 00 00 00 0d 0e de 77 - 70 3a 04 00 00 00 00 00 …….wp:……
0000000008570000 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …………….
0000000008570010 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …………….
0000000008570020 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …………….
0000000008570030 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …………….
0000000008570040 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …………….
*—-> State Dump for Thread Id 0x70c <—-*
eax=00000000 ebx=77dd1b65 ecx=00000000 edx=00000000 esi=0023ddc0 edi=00000000
eip=0044a2ab esp=0c56ff14 ebp=00000000 iopl=0 nv up ei pl zr na po nc
cs=001b ss=0023 ds=0023 es=0023 fs=0038 gs=0000 efl=00000246
function: hserver
0044a272 f7d8 neg eax
0044a274 f7da neg edx
0044a276 83d800 sbb eax,0x0
0044a279 89442414 mov ,eax
0044a27d 89542410 mov ,edx
0044a281 8b44241c mov eax,
0044a285 0bc0 or eax,eax
0044a287 7d14 jge hserver+0x4a29d (0044a29d)
0044a289 47 inc edi
0044a28a 8b542418 mov edx,
0044a28e f7d8 neg eax
0044a290 f7da neg edx
0044a2c7 d1eb shr ebx,1
0044a2c9 d1d9 rcr ecx,1
0044a2cb d1ea shr edx,1
0044a2cd d1d8 rcr eax,1
0044a2cf 0bdb or ebx,ebx
0044a2d1 75f4 jnz hserver+0x4a2c7 (0044a2c7)
0044a2d3 f7f1 div ecx
0044a2d5 8bf0 mov esi,eax
0044a2d7 f764241c mul dword ptr
0044a2db 8bc8 mov ecx,eax
0044a2dd 8b442418 mov eax,
00000000 00000000 00000000 00000000 00000000 hserver+0x4a2ab
000000000c56ff14 65 1b dd 77 c0 dd 23 00 - 00 04 00 00 9e d8 41 00 e..w..#…….A.
000000000c56ff24 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …………….
000000000c56ff34 e8 fe 45 04 28 dc 23 00 - 90 dc 23 00 00 00 00 00 ..E.(.#…#…..
000000000c56ff44 68 00 00 00 a0 dd 23 00 - 03 00 00 00 00 00 00 00 h…..#………
000000000c56ff54 00 00 00 00 00 00 00 00 - 20 00 00 00 25 00 00 00 …….. …%…
000000000c56ff64 00 80 f7 27 00 f0 f8 18 - 00 80 a6 61 00 80 76 5a …'…….a..vZ
000000000c56ff74 00 00 fe 7f 00 50 65 73 - 2a 1b 40 00 00 00 00 00 …..Pes*.@…..
000000000c56ff84 65 00 00 00 01 00 00 00 - b1 11 40 00 28 dc 23 00 e………@.(.#.
000000000c56ff94 65 00 00 00 01 00 00 00 - 00 00 00 00 ec ff 56 0c e………….V.
000000000c56ffa4 00 00 00 00 0c 00 00 00 - 90 7e 45 00 6d 8c 40 00 ………~E.m.@.
000000000c56ffb4 e8 fe 45 04 ed 02 e8 77 - 90 7e 45 00 00 00 00 00 ..E….w.~E…..
000000000c56ffc4 0c 00 00 00 90 7e 45 00 - 94 00 00 c0 00 c0 fd 7f …..~E………
000000000c56ffd4 c0 ff 56 0c 44 fb 56 0c - ff ff ff ff 86 bb e9 77 ..V.D.V……..w
000000000c56ffe4 80 5b e9 77 00 00 00 00 - 00 00 00 00 00 00 00 00 .[.w…………
000000000c56fff4 60 8c 40 00 90 7e 45 00 - 00 00 00 00 00 00 00 00 `.@..~E………
000000000c570004 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …………….
000000000c570014 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …………….
000000000c570024 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …………….
000000000c570034 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …………….
000000000c570044 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 …………….
*—-> Symbol Table <—-*
App: E:\WINXP\System32\hserver.exe (pid=888)
When: 7/1/2003 @ 18:45:01.115
User Name: SYSTEM
Current Build: 2600
Service Pack: None
*—-> Task List <—-*
0 System Process
4 System
388 smss.exe
452 csrss.exe
476 winlogon.exe
520 services.exe
532 lsass.exe
696 svchost.exe
752 svchost.exe
832 svchost.exe
856 svchost.exe
940 spoolsv.exe
1048 nvsvc32.exe
1084 svchost.exe
1108 vsmon.exe
1236 MINILOG.EXE
1496 Explorer.EXE
1692 ctfmon.exe
224 devldr32.exe
284 msiexec.exe
1856 sesinetd.exe
252 mmc.exe
444 dllhost.exe
1276 msdtc.exe
888 hserver.exe
524 drwtsn32.exe
*—-> State Dump for Thread Id 0x46c <—-*
7ffe02db 0000 add ,al
7ffe02dd 0000 add ,al
7ffe02df 00ff add bh,bh
7ffe02e1 ffff ???
7ffe02e3 ff0a dec dword ptr
7ffe02e5 ba0700787f mov edx,0x7f780007
7ffe02ea 0200 add al,
7ffe02ec 0000 add ,al
7ffe02ee 0000 add ,al
7ffe02f0 0000 add ,al
7ffe02f2 0000 add ,al
7ffe02f4 0000 add ,al
7ffe02f6 0000 add ,al
*SharedUserSystemCall:
7ffe02f8 0000 add ,al
7ffe02fa 0000 add ,al
7ffe02fc 0000 add ,al
7ffe02fe 0000 add ,al
7ffe0300 8bd4 mov edx,esp
7ffe0302 0f34 sysenter
7ffe0304 c3 ret
7ffe0305 9c pushfd
7ffe030d 9d popfd
7ffe030e c3 ret
7ffe0313 c3 ret
7ffe0314 90 nop
7ffe0315 9c pushfd
7ffe031d 9d popfd
7ffe031e c3 ret
000000000445fc40 01 00 00 00 00 00 00 00 - 7c fc 45 04 cc 04 00 00 ……..|.E…..
*—-> State Dump for Thread Id 0x4cc <—-*
7ffe02e1 ffff ???
7ffe0304 c3 ret
7ffe0305 9c pushfd
7ffe030d 9d popfd
7ffe030e c3 ret
7ffe0313 c3 ret
7ffe0314 90 nop
7ffe0315 9c pushfd
7ffe031d 9d popfd
7ffe031e c3 ret
000000000856ff80 d8 7e 45 00 90 7e 45 00 - 48 7e de 77 30 03 00 00 .~E..~E.H~.w0…
*—-> State Dump for Thread Id 0x330 <—-*
function: hserver
0044a289 47 inc edi
000000000c56ff54 00 00 00 00 00 00 00 00 - 20 00 00 00 1c 00 00 00 …….. …….
000000000c56ff64 00 80 f7 27 00 80 6e 1c - 00 80 a6 61 00 20 81 5a …'..n….a. .Z
Hardware:
……DVD (O
; CDRW (P
..PCI:
Software:
……ServicePack: NONE
User Name: SYSTEM
Current Build: 2600
Service Pack: None
*—-> Task List <—-*
0 System Process
4 System
388 smss.exe
452 csrss.exe
476 winlogon.exe
520 services.exe
532 lsass.exe
696 svchost.exe
752 svchost.exe
832 svchost.exe
856 svchost.exe
940 spoolsv.exe
1048 nvsvc32.exe
1084 svchost.exe
1108 vsmon.exe
1236 MINILOG.EXE
1496 Explorer.EXE
1692 ctfmon.exe
224 devldr32.exe
284 msiexec.exe
112 IDriver.exe
1076 cmd.exe
1852 hserver.exe
1856 sesinetd.exe
728 gfont.exe
1412 drwtsn32.exe
7ffe0304 c3 ret
7ffe0305 9c pushfd
7ffe030d 9d popfd
7ffe030e c3 ret
7ffe0313 c3 ret
7ffe0314 90 nop
7ffe0315 9c pushfd
7ffe031d 9d popfd
7ffe031e c3 ret
7ffe0304 c3 ret
7ffe0305 9c pushfd
7ffe030d 9d popfd
7ffe030e c3 ret
7ffe0313 c3 ret
7ffe0314 90 nop
7ffe0315 9c pushfd
7ffe031d 9d popfd
7ffe031e c3 ret
7ffe0304 c3 ret
7ffe0305 9c pushfd
7ffe030d 9d popfd
7ffe030e c3 ret
7ffe0313 c3 ret
7ffe0314 90 nop
7ffe0315 9c pushfd
7ffe031d 9d popfd
7ffe031e c3 ret
7ffe0304 c3 ret
7ffe0305 9c pushfd
7ffe030d 9d popfd
7ffe030e c3 ret
7ffe0313 c3 ret
7ffe0314 90 nop
7ffe0315 9c pushfd
7ffe031d 9d popfd
7ffe031e c3 ret
function: hserver
0044a289 47 inc edi
User Name: SYSTEM
Current Build: 2600
Service Pack: None
*—-> Task List <—-*
0 System Process
4 System
388 smss.exe
452 csrss.exe
476 winlogon.exe
520 services.exe
532 lsass.exe
696 svchost.exe
752 svchost.exe
832 svchost.exe
856 svchost.exe
940 spoolsv.exe
1048 nvsvc32.exe
1084 svchost.exe
1108 vsmon.exe
1236 MINILOG.EXE
1496 Explorer.EXE
1692 ctfmon.exe
224 devldr32.exe
284 msiexec.exe
1856 sesinetd.exe
252 mmc.exe
444 dllhost.exe
1276 msdtc.exe
888 hserver.exe
524 drwtsn32.exe
7ffe02e1 ffff ???
7ffe0304 c3 ret
7ffe0305 9c pushfd
7ffe030d 9d popfd
7ffe030e c3 ret
7ffe0313 c3 ret
7ffe0314 90 nop
7ffe0315 9c pushfd
7ffe031d 9d popfd
7ffe031e c3 ret
7ffe02e1 ffff ???
7ffe0304 c3 ret
7ffe0305 9c pushfd
7ffe030d 9d popfd
7ffe030e c3 ret
7ffe0313 c3 ret
7ffe0314 90 nop
7ffe0315 9c pushfd
7ffe031d 9d popfd
7ffe031e c3 ret
function: hserver
0044a289 47 inc edi
- JoeFrog
- 7 posts
- lucas
- 269 posts
Thank you for your help, JoeFrog. We believe the problem has been fixed in version 6.0.353. It should be available on the download server ( http://www.sidefx.com/dls/ [sidefx.com] ) within a week or two.
- kamcm75
Joe -
I have the same problem – I get as far as the splash screen and the program crashes! (I'm a liitle luckier than you - my XP will load in it about every 50 - 100 tries! When it does, I get an error message that it couldn't run the program!)
I guess we'll both have cross our fingers and wait to see if the problem gets solved in the next release….
Good Luck!
kamcm75@37.com
Good Luck!
kamcm75@37.com
- stevenong
- 1634 posts
Hi there,
Cheers!
steven
kamcm75I believe your problem is different from Joe's. May I know what graphics card are you using?
Joe -
Cheers!
steven
- Noxerus
- 10 posts
- edward
- 8081 posts
