Hi all,
My question might be quite obvious but, does houdini support vertex normals? How do I calculate them?
thanks
kuba
vertex normals
6883 6 1-
- kuba
- 345 posts
- hoknamahn
- 398 posts
- Mikael_Amion
- 129 posts
Not that I wish to rub salt into anyone’s wounds but isn’t it so that until vertex normals in OpenGL are supported Houdini won’t be reasonable to use in a game production. I know that it has been used several times before but the fewer amounts of vertices that have to be calculated the better right? Cusping edges for real-time doesn’t seem to be a good option in those cases.
- photex
- 119 posts
It was my understanding that even in applications that support vertex normals by the time you export for engine you're still going to be drawing a separate point for each varying normal. In these cases Houdini would be more representational of the data that gets drawn then.
—- edit —–
which isn't to say that the whole working with normals thing in Houdini is somehow better or easier…
—- edit —–
- Mikael_Amion
- 129 posts
photex
I´m not sure about that though. Having double points for skinned objects doesn’t really make sense for optimized performance either. If you take the .obj format and open it up as a text file you’ll find the same point count as you had in the source app and an accompanying “vn” attribute for each vertex normal. But it might be as you say that some engines do it that way.
- photex
- 119 posts
It's definitely per engine in terms of how they like their data cooked.
I also wouldn't consider the obj format a great representation of how data will be organized for a game engine.
I asked this question of a Gamebryo engineer recently in concerns to how their mesh data is handled. The answer I got was that if you have a hard edge, you really have two edges. I couldn't really get into details, but I was told that meshes are highly optimized per platform so it can depend on that as well as whether this was an actor or static mesh, pc or ps3, etc etc.
- Mikael_Amion
- 129 posts
