how can houdini judge the corner of the polyline
10393
9
2
syzmatrix
May 8, 2009 12:40 a.m.
hi everyone
Here is a simple question.
can houdini judge the coner points and seperate the polyline into different lines,I just want it to be procedurly.
syzmatrix
May 8, 2009 12:41 a.m.
here is the attached file. :?
ttttt.hip (42.7 KB)
probbins
May 8, 2009 10:29 a.m.
I don't suppose a 2nd carve sop is what you are looking for? Using first U to locate the corner and keeping both inside and outside. I would perhaps be nice if you could identify a specific point on the curve and turn on Breakpoints for that location.
“gravity is not a force, it is a boundary layer” “everything is coincident” “Love; the state of suspended anticipation.”
syzmatrix
May 8, 2009 10:50 a.m.
hi probbins thanks a lot for your reply! I just think about the same thing. The problem is clear now. How can I find the corner point by houdini:it is really confusing me a lot.
May 8, 2009 11 a.m.
Use the poly extrude SOP
Find the normal that is not pointed in the same direction as the primitive normal.
Should be good to go!
cheers,
-j
syzmatrix
May 8, 2009 2:54 p.m.
jacob clark,thanks very much for your reply. I will try it soon. :wink:
syzmatrix
May 9, 2009 1:40 a.m.
here is what I get now. The question is more and more approaching its goal. I can find the primtive normal and the point normal. But there is still some problems that I do not know how to put the point normal and the primtive normal together to compare. Hope some nice guy HELPS! :shock:
syzmatrix
May 9, 2009 1:41 a.m.
here is the hip file
ttttt.hip (54.6 KB)
Simon
May 9, 2009 7:08 a.m.
could you remove inline points using the facet sop and then the end points the one left is the corner…..
Edited by - May 10, 2009 05:16:45
syzmatrix
May 10, 2009 3:18 a.m.
Thanks very much for you reply, Simon.
I take you method and work it out. It seems to be a good solution for the problem.
It is a part of a much bigger project, and there are still some problems.
Thanks for all the help you offer!
