Force number of points on curve
9091 8 1-
- Soothsayer
- 875 posts
- jacob clark
- 665 posts
- Soothsayer
- 875 posts
- kuba
- 345 posts
- Soothsayer
- 875 posts
kuba
Resampling nurbs curves this way converts them to polygons. Refine (unrefine) sop is the different approach, but I still have no clue how to determined exact number of points there.
I don't have H here now but if I remember correctly: append refine SOP and then set first u point to 0, and second to 1 (beginning and end). You should be able to work out how the total point numbers are related to subdivision. I think it was points = npt + (u-2) or something like that. You set p to a value that is 2 higher than the maximum you'll ever get in your curve, solve the equation accordingly, and that way you'll always retain the same number of points.
Jobless
Jobless
- kuba
- 345 posts
Thanks for the tip. Unfortunately you can only Refine it (increasing number of points). If I need to rebuild Nurbs curve by decreasing the number - Resample SOP is the only way to go. Unfortunatelly Unrefine can't be set up to control final number of points.
In the end maybe Resample SOP is the best way for that since it evenly distributes points on the curve… and you anyway tweak the final shape afterwords.
Kuba
Kuba
- Soothsayer
- 875 posts
- Anonymous
- 678 posts
- 9417 posts
