CHOPS and Audio Deformation of Geometry aka Grid
   3818   3   2
I have Apprentice HD 10 on Win 7 64bit and I am wondering if I can have a stereo file used to make the effect that I want? Also am I just limited to .WAV files on Windows?
DJ
“Nothing is just Black & White”- look at the Yin/Yang symbol
What effect do you want to achieve with the audio?
Generally two methods to take audio and drive animation:
1. Amplitude enveloping of the waveform then process using Area and Slope for peaks, valleys, and slope/accelerations. Logic used to Trigger events.
Good for driving a single overall parameter of your effect at a time. Process the audio in several ways and combine the results for dynamic results.
2. Return the Spectrum (or power) of the audio waveform to affect a broad range of attributes at a time.
Example files should be there for many of the CHOPs referenced above.
Andy Lowell wrote a book on using CHOPs to process audio and data in a great amount of detail.
Also, you can find good tutorials on mr. Piter Quint's vimeo chanell:
http://www.vimeo.com/user2030228 [vimeo.com]
djorzgul
Actually I just found that I missed it when looking to see what he had and I seemed to have missed them when I went through to download.. ops:
Thanks Jeff: what I want to do is: take a grid subdivide like what peter quint has on his for-each tutorial and randomise the primitive motion on the y axis.
DJ
