HD render license gone...(Solved)
   3078   2   0
Hi guys,
I decided to dual boot my pc with ubuntu and install 64 bit version due to a recent purchase of 4 gb of ram.I uninstalled houdini on the windows side and redemed my licenses.Installed on linux and everything was fine untill i tried to render.I logged in to license administrator and i see only 3 licenses,2 for non commerical and 1 for HD.
Is this right or is there a way to fix this without having to buy another HD license?
Thanks in advance
Ian.
Edited by - March 29, 2010 15:30:47
yes, three license keys are correct: one for running houdini, one for rendering, and HD for removing the resolution/watermark restrictions.
What problem are you running into when you try to render? You can also try sending the diagnostic info (from the license administrator utility) to support@sidefx
Thanks for the reply rafal,
I got it sorted.It ended up that the render license was still tied to the sever for vista and that it was one that I forgot to redem. reinstalled Houdini on vista sent the license back.
Went back into Linux and installed the license and I can render now.
The detailed reply is for other user if their having the same problem.
I do find that alot on these forms that people ask for help and get a solution but dont finish the thread.
Again thanks for the reply and help rafal.
Ian
