How to calculate volume and surface area of models
   19391   4   1
I am using houdini to model the prototype of an RC-vehichle we are building. Houdini is great for modeling physical conditions like drag, gravity, friction etc., but now that we're actually building the thing in real life I need to determine the volume and surface area of each part.
Is there a straightforward way of doing this?
you can use
Measure SOP
it can compute Area or Volume per primitive as Primitive attribute
then to get Area/Volume of the whole input mesh you need to append
AttributePromote SOP
and set it to
Original Name: area (or volume)
Original Class: Primitive
New Class: Detail
Promotion Method: Sum
then you can find Detail Attribute of the same name on your geometry and it will contain Area/Volume of the whole geometry
CG Supervisor
Framestore, NY
Excellent, just what I was looking for, thanks!
Now, when I have the volumes and areas inside the different objects, is there a straight forward way of displaying these properties next to the objects in a viewport?
not sure if straightforward enough but you can
create font SOP
in text parameter write some expression like
Volume : `detail(“../null1”, “volume”, 0)`
../null1 is the path to SOP which contain Detail Attribute named “volume” and it's value will be returned by detail() expression
CG Supervisor
Framestore, NY
It works perfectly, thanks again!
