DOP VEXpression Variable_name
   976   5   1
hi,
How can I find out the DOP parameter variable names?
Most of the time no errors occur using variable name by tooltip-message,
but sometimes an error occurs due to the variable name.
In popwind(DOP), Wind_Velocity(x) shows "windx", but it will not work correctly unless it is actually wind.x.
In other case, popFanCone(DOP), Position(X) shows "tx",
but tx, t.x, positionx, position.x, all of these will cause an error.
thanks
t.x, t.y, t.z work for me.
thanks
//correct ()
vector center = (t.x, t.y, t.z);
//incorrect {}
vector center = {t.x, t.y, t.z};
t.x work well fot me too.
Noboru Saka
thanks
//correct ()
//incorrect {}
or use
vector center = t;
since t is the actual parameter name as well as the variable name coming to VEXpression snippet inside
or of course you can use t instead of wherever you use center directly
Noboru Saka
//incorrect {}
As a rule, the curly braces will only accept constants, no variables.
I normally use { } for Vector types ex.{0,1,0}, so I thought it was strange that an error occurred in this case.
I'm happy I now know the reason.
thanks
