Hi!
I have a geometry with a specific point I would like to split/unfuse. Is there a node for that? Or, is there a way to automatically group this kind of point? (I could use that group in a point split later).
-Olivier
Unfuse or Group this type of Point? {[SOLVED]}
2009 6 2-
- olivierth
- 1193 posts
- majstorovich
- 40 posts
Is that point always perfectly in the middle?
If yes, use a Group with 'Keep in Bounding Regions' and set up bounding box accordingly
https://twitter.com/majstorovich [twitter.com]
https://www.youtube.com/myMotionExperience [www.youtube.com]
- olivierth
- 1193 posts
- vicvvsh
- 59 posts
- olivierth
- 1193 posts
- ajz3d
- 654 posts
I don't know how you are constructing this object, but for this type of topology, that is, if your future geometry variants will be created in mostly the same way, perhaps the optimal solution is just to group points with a valence greater than four or five? Group Expression SOP comes with a predefined VEXpression which does just that. Look for "Point Valence".
Edited by ajz3d - April 27, 2025 15:35:22
- olivierth
- 1193 posts
