I attached the hip file. I have an object then apply rbdmaterialfracture and set the constraint strength to very high value so the object stick together. I modify the constraint's color to make some constraint white. Inside the rbdbulletsolver, i add geometry wrangler and modify the constraint's strength to 0 (if the color is white):
if( @Cd.r >0) {@strength = 0;
It should break on the right part but it's not working . What is wrong ?
metaclay2 It should break on the right part but it's not working . What is wrong ?
your setup seems working and @strength is 0 for those constraints
however, even 0 strength Glue constraints need impact to break, since Glue objects are treated as a compound RBD with singular COM therefore there is no strain between pieces of the same glued RBD
if you want them to break immediately you can assign them to broken group @group_broken = 1;
