rbdmaterialfaracture can't fracture this piece.
   619   1   1
I attached the hip and bgeo file. I tried to select 1 piece from the fractured object then add 'rbdmaterialfaracture', but for some reason it's not working. Nothing fancy setting just default. I check there's no unshared edges but why the fracture fails ?
I tested using voronoi fracture and it works but this rbdmaterialfracture does not work.
I'm using 20.5.613
Edited by metaclay2 - June 11, 2025 21:50:05
nofrac.hipnc (612.2 KB)
test_01_v1.bgeo.sc (285.9 KB)
On the RBD Material Fracture SOP, play with the Fog Volume > Noise Type, Noise Frequency and Offset. That piece happens to be in a region where the default noise values seem to be 0 which ends up generating no fracture points.
