Can I switch between Z-Up and Y-Up orientation from script? I'd like to have some sort settings for projects so I can use the same orientation as my target
I see this enum: https://www.sidefx.com/docs/houdini/hom/hou/orientUpAxis.html [www.sidefx.com] but couldnt find any function to actually set it
Is it possible to switch Y-Up/Z-Up from script
699 1 0-
- elovikov
- 151 posts
- elovikov
- 151 posts
Just for visibility my workaround.
It seems the setting cant be set via script but at least it can be set per package basis. So if you have orientation.val := "Z Up"; in houdini.pref in package directory it'd be loadad and set as the global viewport orientation.
Unfortunately preferences then saved in HOUDINI_USER_PREF_DIR so it means whatever setting was loaded the last it become your default
So currently I have this:
- In pythonrc.py I just set Y Up as default by brute force, just writing it explicitly to HOUDINI_USER_PREF_DIR
- Then in any package I want it differently I'm adding houdini.pref with Z Up
It looks like I'm missing something obvious
